Originally Posted By: Swift101
Hey All,
I may run 5W-40 in the future, I noticed Walmart has Mobil 1 (the turbo diesel truck version) but not "Mobil 1 Formula™ M 5W-40". I know Rotella T6 is an option as well, but it's technically not supposed to be used in my engine.
Also I could use Pennzoil Ultra 5W-40 Euro (online order only), but are there any other 40 weight oils Walmart sells?
On a side note, I can't use 0W-40 since I'm under warranty.
I'm planning on doing a used oil analysis on both 30 & 40 weight oil to see which on stands up to my driving conditions.
-Thanks
When you say "I can't use 0W-40 since I'm under warranty", it makes no sense at all. How would a heavy-duty-diesel-engine oil (5W-40) be OK in your gas-engine application while a gas-engine oil with virtually the same cold, hot, and high-shear viscosity but better extreme-cold viscosity wouldn't be OK?
If you want to use 40-weight oil, Mobil 1 0W-40 SN is the way to go, not a 5W-40 heavy-duty-diesel-engine (18-wheeler) oil.
