I did another experiment for fun and out of curiosity ...
Took 2 clean & dry glass cups from the kitchen.
Filled to 1/3 with PP 5Wx30 and Mobil 1 Extended Performance 5Wx30.
Labeled accordingly.
At room room temp both oil had relatively similar color & very clear.
I Could tell that PP was a little thinner when shaking the glass but by not much. PP KV40 is about %10 lower than that of Mobil 1 Extended Performance.
Covered both glasses with plastic wrap and placed in he freezer (digital readout = 1°F).
after a week, I took them out.
I could easily tell now that PP was thinner. It flowed much easier than M1.
PP color was very crisp & clear.
M1 looked foggy everywhere ... Once it started to warm up to room temperature, I could see little white (milky) clouds floating around. Not very thick but more of a see through clouds.
Also I could see a little white residue (on the glass) where I had shaken the glass before going into the freezer.
PP also developed a very small see through white clouds after being out of freezer but not much. I didn't notice it when I took it out of freezer but when I was shaking the glass later I noticed a very small cloud.
an hour later and after walking the dog ....
White clouds are all gone and M1 color looked as clear as PP and like new from the jar.
I know this test may not prove anything ... but I was impressed by how clear PP was at 1°F.
Qurstion:
what is the milky/white stuff? is it an additive? I can't imagine it's moisture! Is it? The fog was everywhere! It can't be wax either since ep is a very good oil!
I'm may repeat the test depending on what you guys think.
Qurstion:
