White Lithium Grease
NC
I have a few ATV's that have Zerk fittings for the bottom wheel hub bushings. I have always put regular grease in them and after a while the grease that gets pushed out gets very hard and the rubber bushing caps dont seal well. I was wondering if a lighter white grease would be a better option. Also around where the CV joint sits up against the rubber seals. I use regular grease to lub that up but im thinking the white grease might be better. Any feedback will be appriciated.
I've found the white grease to be close to useless. Bel-Ray waterproof grease (aluminum complex base) is a far superior grease, easy to find in many motorcycle & ATV shops, and much more waterproof.
