I doubt that as the wear bars seem to go right across some of the dots.That's wild. Just a guess...Maybe where the computer wanted the tread bufffed down, to buff off the high spots?
Do all four tires have these dots? Maybe CapriRacer knows.
Why would cord belts show through the rubber of a new tire in random places? I ran my finger over the dots, thinking the same thing, and the feel was perfectly smooth, although I'm certainly not sure what that means, if anything.Tire carcass cord belts
Thanks ... I don't, wrong sizes and dates.See if you qualify for the Recall >>>>>>> https://www.consumerreports.org/car...lls-tires-due-to-risk-of-sidewall-separation/
This ☝its production markings. The paint that went into the grooves will take longer to wear off....That is just the markings that the factory puts on the "green" / uncured tread. The color combinations help to keep track of the identification or tread width. There is usually a tread code, date and there info printed on the tread. Most of it is on top of the tread, so it wears off quickly. The stripes in the grooves actually can help the final inspection workers tell if the tread was built onto the tire straight and centered.
