96 f250 5.8 351w 64xxx miles 2wd e40d
truck was smashed from the back on 2021. insurance fully rebuilt rear end with some used parts. got back with at 573xx miles.....now has 64xxx miles. just got new oversized tires 305 70 r16 toyo at (just ran same tires to 50k, oil changed w Pennzoil Platinum High Mileage 10w30, transmission 100% fluid change with Mobil D/M and fram filter, rear differential fluid changed w synthetic valvoline.
All work done by licensed shops.
truck makes a steady whining, groaning, almost identical to howling wind. noise most noticeable on deceleration. shifts perfectly fine, trans and oil at exact spot on dip sticks. nothing wrong with drivabulity thus far. want to fix noise before it turns into something bad. sounds like its coming from the rear of the vehicle when i stick my head out the window.
where should i begin looking? ideas as to what these symptoms sound like?
Thanks in advance for any replies.
