Which trans additive for 08 Focus
ffl
Illinois
Just wondering about additives for the auto trans in my Focus. Car has 130,000 miles and fluid exchanges were done at 30, 70, and 100,000 miles. Dropped the pan and changed the filter and 3.5 qts. at 120,000 miles. I think shifting could be smoother even though there are no codes. Which Lubeguard or other product would you recommend, if at all? Thanks
I think the 08 uses the Mercon LV unlike the 07? I don't think the Mobil 1 is compatible.
Fords ATF, no need for any additives. I know what you mean about rough shifting. I just rode in an older focus recently and it had sort of a "thud" into ever gear.
I have to read the boxes each time for the correct one. There are 3 different formula's I believe. Use the one that is for Ford products....I think it is green? Great product and they claim that the OEM's use it on the factory line fill.
I recently added Lubegard Red to a GM w/ 4L60E running Maxlife Dex/Merc and a 2001 Honda CR-V 4-cyl running Honda Z1. Shifts feel smoother with quicker engagement, if that makes sense. Shift quality definitely changed, and for the better.
I started using it on the recommendation of a friend who has been rebuilding and servicing transmissions for the past bazillion years.
The 32oz bottle is relatively inexpensive on Amazon.
LG red is what you'd in that transmission.
Yep, that's the only one I would put in our transmissions.
On a recent ATF change (Motorcraft Mercon V) in my 03' Ford Focus....I added Lubegard RED (one oz. for each quart of ATF).
As Strat81 mentioned, my transmission shifts feel smoother and engage very quickly. I'm completely satisfied with the results.
The reason I decided to use it was because I read on this site that some transmission builders use Lubegard on every re-build. To me that was a positive recommendation for the product.
You put 32oz in the 4L60E?
I just put a 10oz bottle in my car, and wondering if I should add more.
Instructions say one ounce of LG for every quart and my trans holds 11.5 quarts.
So, by their calculations I should add another 1.5oz of LG.
Biggest reason I feel that Lubegard should be added to any brand of fluid is that fact that it brings the fluid temperatures down. Less heat = longer life.
No, I put in 12 oz. The 32oz bottle was cheaper, plus I threw some in my Honda too.
Definite +1....and one of the main reasons I added Lubgard Red when I last changed my ATF.
Since I put in the Lubegard Ive noticed a better 1-2 shift on hard acceleration(less lag, quicker) and no more clunk into reverse.
I'm gonna throw another 10 oz in right before summer hits to keep the fluid temps down.
