Which tire protectant?
West Michigan
Not interesting in tire dressing, per say, but in tire protectant. Is 303 still the best option? Anything better? I drive my 2011 about once a week and put less than 2000 miles on it last year. Tires will DEFINITELY age out before wearing out but I wouldn't mind buying some time if possible.
This is like 303 that stays on better. Not glossy at all. Great stuff.
Tire Dressing, Tire Protectant, No Tire Shine, No Dirt Attracting Residue 32oz Natural Satin/Matte Finish, Aircraft Grade Rubber Tire Care Conditioner, Better Than Automotive Products https://a.co/d/hAE7dr3
I love 303. However, I’ve tried it on exterior parts including trim and tires, and it just doesn’t last long. Any water it goes away and streaks. If it’s sat in a dry climate it would do fine.
I have used 303 for years with good results. In recent years I have used Rubber Care as it is cheaper. I apply monthly. When I had cracking on the inner side of the tires many years ago I started applying 303/Rubber Care there every oil change (~6-8 months). I guess the ozone gets to the inner side as it doesn't get any UV there like the outer sun side gets. It is a hassle but I have greatly extended the time before cracking appears by several years to about the time I replace the tires at 6 years or so.
I bought some a few years ago that's supposed to help dry rot for a tractor, but I never used it, forgot what I did with the jug even 🤣
303 used to make a specific product for the purpose -- Tire Balm.
It was a snot-like product like Meguiars' Endurance, and had a more satiny finish, but was discontinued.
I've come to consider tire dressing products as cosmetic products that under most circumstances are unnecessary; tires have some degree of UV protection built in, and in other circumstances, like an RV parked outdoors for long periods, there are probably better ways to protect them from UV.
I like Backfire Tire Gel - good UV protection and leaves a nice finish. Not a huge fan of 303 for tires, just not its purpose.
https://www.autogeek.net/blackfire-...FvLYSt2F3lplutDToQRRr33eIE6lZdkVf6VE9F1QYYq0b
I mixed Griots and Aero Cosmetics 60/40 as I found the Griots to be too shiny and the Aero Cosmetics to be too blah. It’s the right mix for me.
I’ll post a pick when I get back home.
I do prefer a shiny tire protectorate in spray form for ease of application but am concerned about the vehicle used for spray that could cause drying or other issues affecting tire life. Which tire spray would be considered the best for this purpose?
I bought some new tires for my truck in the fall. They were getting kind of brown. Put on 303, and they looked good for awhile. But they are turning brown again.
I think I need to scrub them with a natural scrub brush to get the brown off. Then scrub with simple green, then apply 303 again. I'm trying to use 303 on everything.
Pics, please.
I use Aero Cosmetics and like it.
303 would be my second choice.
I use the regular 303 on our tires. Seems to keep the tires cleaner for longer, and helps prevent the browning/blooming somewhat.
IIRC, that browning/blooming is UV protectant releasing from the tire that occurs when you drive from it flexing. Don't know the answer but maybe its a good thing to let the tire do that instead of sealing it in? Would like to know...
All rubber will bloom naturally. Sometimes it’s white. But removing it isn’t harmful. As for the UV part, I don’t know. But the brown looks terrible so I like to remove it. I’ve never had tire life shortened by applying 303, which itself is a UV protectant.
