Which timing chain cover gasket set?
Indiana
Happy Saturday folks.
I have the front end of my Jeep off for a variety of reasons and I noticed my timing cover gasket is leaking. Might as well replace that while I am in there and if the timing chain is sloppy (which at 200k it may very well be), I might as well replace that too. I've seen if there's 1/2" of play, the chain should be replaced. Meanwhile, I've seen that they should be fine for the life of the engine.
Anyways, Oreilly has 2 FelPro gasket sets. Which one should I use?
https://www.oreillyauto.com/detail/fel-p...in+cover+gasket
And I just realized I put this in the Auto General Topics sub-forum..
Originally Posted By: krismoriah72
That second link has two tubes of stuff with it for an extra $1..so i would pick that one lol.
2 tubes and an extra gasket/ ring.
Never done the job before so I don't know what it would be for.
Also, I am not a fan of gasket makers if it didn't come with it from the factory.
The gaskets look identical to me, I'd also get the one with two gaskets...nothing worse than needing the 2nd gasket, not having it, and dancing around in the garage yelling about it.
Originally Posted By: Kuato
Nothing worse than needing the 2nd gasket, not having it, and dancing around in the garage yelling about it.
You know me too well.
