While I fully agree that you may have a problem running MercV in some applications, if the transmission is in good shape you should have no problems. I have 4 4r100's that have all run MercV for anywhere from 50 - 272K, all without a problem. I think that the MercV (depending on the refiner) is a higher quality oil and works much better cold than Mercon does.
With the oil MolaKule shipped me, I get the best of both worlds, great base oil with the best add pack for the app. Still, I would run MercV again if I couldn't source any fluid such as that from SF. If I was going to have a problem either of the 190K or 272K mile trans should have had that problem.
All three transmissions have the BD Power accumulator valve body and lockup controller. The two high mileage trans both had TC clutch failures, so I replaced the factory converter on the low mileage one before it failed. The TC clutch failures were not related to oil, IMO, but due to poor materials. All three of these trucks spend most of their life towing 18,000+ trailers.
Also, the previous version of B400 frictions to the current stock we have at work were very close in composition to the 4r100 OEM ZF clutches (at least they were in 2001 ZF’s), and as I stated before the MercV has given the best performance of any oil we have tried to date. We have not run full syn due to price. With 1500 trans, that would be very expensive. Even in our newest Allison’s, with a replacement price of well over 120K dollars, we run MercV with great results.
I don’t disagree that MercV can cause problems, however I think a transmission in good shape and well maintained will do fine with that fluid, but this is based on my experience and no hard data other than some UOA’s from Allisons at work.
Patrick
