This is about my 2001 Dodge Dakota pickup truck. It has a 3.9 liter V6, 5 speed manual, just shy of 162,000 miles on it now. This morning the CEL came on, and with my truck I can do the "key dance" to display DTC's in the odometer. It is showing P0432 which is for the right exhaust catalytic convertor being at half of its specified efficiency.
I am at work but was able to do a little research on it, and it could be the downstream O2 sensor causing the problem. I replaced the upstream O2's about 60,000 miles ago, used NTK parts. The downstream O2's are still the orignal Mopars. I need a good scan tool to test the operation of the O2's but I am confused on which one to buy. I do not need nor can I afford a pro-grade Mac, Matco, Snap-On or other pro tool. Actron or HF is more in my budget but I don't know much about the scanners to pick the best one for checking O2's.
I appreciate any help/suggestions on this. I need to rule out the O2's before I replace the cat. I would much rather just replace the O2's. Thanks.
