Which oversize filters?
Southeast
For a Toyota 3.4L Im using a MC FL-400s instead of a 3614.
For a 4.6L crown vic, is an FL-1A the bigger version of the FL-820S?
And what is the bigger version of the chevy 3.1L filter? The delco number is PF47, not sure what the fram number is. I ran a bigger one before, but forgot the number.
And whats the best cartridge filter for a 2.2L ecotec? Ive just been running the Supertech, they all look the same out of the box anyway.
Thanks!
I belive you are stuck with the FL-820S as I have never seen an oversize for that one. The oversize for the GM is PH3980 or equivalent. Ecotec filter not sure, but some have liked the Fram, actually. If they all look the same, buy on price/availability.
Originally Posted By: LT4 Vette
There is an oversize for the FL-820, but its like 10 bucks.
Why bother ?
Good point. Plus the Vic takes an even 5 qts with stock filter.
The 3.1L Malibu takes 4.5 with stock filter...would be great to squeeze an even 5 with the 3980. Tundra takes an even 6. Cavalier takes 4.5 by the book, but I think 5 is no problem.
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-08), Mazda (00-08), Cadillac STS-V, XLR-V (06-08)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
P550166 - donaldson to Wix
Part Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Nominal Micron Rating: 16
Gasket Diameters
15614 2.834 2.462 0.255
P553315
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
By-Pass Valve Setting-PSI: 19
Burst Pressure-PSI: 355
Nominal Micron Rating: 24
Gasket Diameters
