Propflux01
$100 Site Donor 2025
Decided between these two oils to run in a 2021 Kona. I already use the 5w30 in a Tucson, but the Kona is the Turbo GDI. Thinking maybe the 40 for that. Or maybe the 40 for both? Opinions?
i changed it, is that better?OT: Better thread titles help everyone and makes searching "not suck" Please....
Yeah sorry I corrected my post. The Edge 5w30 LL with 504 00 approval. The 0W-40 product is high SAPS.Both are Castrol, which one of the products you specifically referring to? The 30, 40, or both?
Yes, that’s where I have been buying it For the Tucson. I just wasn’t sure if the Kona turbo “needed” an extra viscosity boost. The manual says I can use a 30,40, or 50 oil.Yeah sorry I corrected my post. The Edge 5w30 LL with 504 00 approval. The 0W-40 product is high SAPS.
You can't find a less expensive 504 00 oil than the LL available at Walmart.com for $24.04/5 quarts. If you buy two then shipping is free.
Well you won't get it between those two. If you want that then something with a higher HT/HS would be required. But these with an HT/HS of ~3.5 is pretty good and there are few engines that would require more. I use the LL product in my new Tiguan and I think it's what VW used on my last free change.Yes, that’s where I have been buying it For the Tucson. I just wasn’t sure if the Kona turbo “needed” an extra viscosity boost. The manual says I can use a 30,40, or 50 oil.
What does the LL mean? I don't see it on the 0w20.Both those are going to be virtually the same HT/HS so in that regard they are functionally identical.
The Castrol LL product has VW 504 00 approval and is a medium to low SAPS oil, that's the only substantive difference. It's what I'd use.
“LL” is designed for VW engines if I remember correctly. I don’t know what it actually acronyms as.What does the LL mean? I don't see it on the 0w20.
I believe the higher zinc and phospHorus counts offset the calcium amounts that cause lspi. The added titanium does as well. Also, most lspi issues have been resolved in most newer engines nowadays in normal driving.Isn't the turbo GDI engine the poster child for the LSPI problems? I'd choose an oil specifically designed to be used to deal with the LSPI. Neither of the two oils you submitted are noted for such. Dexos-1, gen 2 is a common specification as is the newest API SP.
I own nothing with a direct injected engine or a turbocharger so I'm just opining from the data that's out there.
It should be the new Smartstream engine, I'm not sure how they are in terms of LSPI, but still it's a little 1.6L engine in a fairly heavy car so an LSPI friendly oil is probably a better idea, and being a new smartstream engine with dual injection at least it has some fuel washing the valves so high SAPS oil shouldn't be as problematic as it'd be in a purely direct injected engine, Pennzoil/Quaker State Euro 5W40 would probably be a better choice than these two oils although it's a high SAPS oil. If you wanna go Low SAPS there's Mobil1 ESP 0W30 and 5W30 that are MB229.52 so they have a high HTHS>3.5 and LSPI protection but it's usually pretty expensive.I'd choose an oil specifically designed to be used to deal with the LSPI. Neither of the two oils you submitted are noted for such. Dexos-1, gen 2 is a common specification as is the newest API SP.
But the LL is only ACEA C3 rated and only carries approvals from European manufacturers that don't have LSPI tests.Yes ESP is more expensive then the Castrol Edge LL listed above. And the Castrol is slightly lower in ash.
