I have a 2013 Yamaha FZ6R and I was looking the owners manual to see what oil was recommended and it says the following:
Engine Oil:
Recommended engine oil grade:
API service SG type or higher, JASO standard MA
Does that mean I need an oil that is both, API and JASO MA? Or one or the other? If it's one or the other, which one is the better standard for better quality oil?
Also when you look at motorcycle oil, are they wall wet clutch compatible or there is spec somewhere on the bottle that means that the oil is wet clutch compatible?
Engine Oil:
