You might try something like Mobil 1 0w-40, GC 0w30 (a thick 30w), various, somewhat rare, 0/5W-50 oils, or similar. Some of Redline's stuff also combines good cold flow and high HTHS.
http://www.redlineoil.com/content/files/tech/Motor Oil Product Data.pdf
The combination of 0W and Syn implies "thin at low temp," which might reduce the 20 seconds of heavy metal noise at startup.
Once the engine has warmed, the 40+w should help your bearings a little.
IF your main bearings really are significantly damaged, nothing short of axle grease is likely to stop their continued degradation. You might slow the rot, but I'd start saving my pennies for a teardown.
