Quote:
my mistake, the 850 has the 2.4 I5
my ride is the 2.3 I4
Nothing at all wrong with riding a beautiful old red block. And yours should indeed love a 40.
Quote:
Quote:
Quote:
The Volvo drives a lot of stop and go, even on the highway (I290 for locals).
The pavement you're crawling over is around 120 degrees F so your oil temp will be around 20 degrees hotter than normal after several minutes of stop and go. Run short intervals OR use full synthetic.
so 140°f is too hot for conventional oil?![]()
Quote:
Radiant heat is always there regardless of speed. It is the lack of airflow that that challenges a cooling system. Everyone with an oil temperature gauge has reported drops in oil temperature when coming off of highway travel into stop and go.
Quote:
Most of the time this is true, but not in the very hot summer. In the very hot summer if I've got the AC blasting and I'm on the highway my oil will be at about 210F, but once I get off the highway and I'm stuck in traffic, if my AC is still on I've seen my oil temps go close to 230F. I've never seen the oil temps get anywhere near that hot at a steady highway speed though, only in stop and go.
Quote:
Interesting and it sounds like heat soak due to lack of airflow immediately following a steady state. How long does the event last?
Quote:
In theory the heat shoud dissipate through radiation given enough time, but I believe your spike is another good indication why GM requires a synthetic oil for the Corvette.
Quote:
I also imagine the engineers and designers didn't have sitting in heavy traffic in mind when they designed the vette. My perspective is scewed towards trucks and 4x4's with cooling systems designed for low speed high load.. So from one extreme to another.. What about the middle? How does your wifes Honda ofr a minivan react?
Quote:
(And yes Volvohead, I know I have to use Mann as a self-respecting Volvo owner, but I had no time to get one onces I had time to change the oil. Mann filters are not available around the corner if the dealership is closed, where they are expensive anyway. PureOne is a good alternative.)
