I have a Kawasaki 21hp FH941V engine on a Gravely zero-turn mower that gets run about 6-8 hours at a time, every other week. West Texas, typical summer temps right around 100, with LOTS of dust (thin grass, 10% humidity).
The engine manual calls for straight SAE40 oil, and shows 10W-40 up to 90 degrees F, which of course if 10 degrees too cool. It also says "using multi grade oils will increase oil consumption, check oil lever more frequently when using them."
My problem is that I can't easily get straight 40 oil locally, but I can get every flavor of multi-grade __W-40 and __W-50 in both conventional and synthetic.
Anything wrong with using a synthetic 10W-40, or maybe a __W-50?
The book also calls for oil changes at 100 hours, but I've been doing them yearly - which is less than 100/year.
