Which flywheel puller should I get ?
Clovis, CA
1. ebay
2. ebay
3. ebay
I kinda like the first one because it's retro, but I can't make up my mind.
Originally Posted By: Eddie
Why don't you lift on the flywheel and hit the center bolt with a plastic end hammer?
That method is actually in Briggs some Briggs manuals.
I'm done smacking the flywheel and smacking the crankshaft. I've broken to many cooling fins doing that. It's time for the correct tool. All you guys gotta do is click on 3 links and tell me which one you'd choose.
Originally Posted By: dlundblad
1 hands down for the reason you mentioned above.
Also, it's a little cheaper than the others.
+1
1
Nicer box, looks more substantial.
You'll need shelving in a shed to display the box to full advantage, but I'm assuming you already have that.
