Those would probably work fine, but for $5-$7 I can buy 15+ aluminum or copper drain plug washers on Amazon, and also don't have to worry about any rubber in the drain plug seal to not degrade over time and use. Al a Cu drain plug washers have never failed me in decades, even when reusing them many times. I don't "anneal" the Cu washers, they seal just find over and over with the proper drain plug torque spec from the manual. If I see any sign of cracking or degradation, a new washer goes on, but I've used some 10 times with no signs of degradation.A better option IMHO is a Stat-o-seal with the viton liner. Requires very little torque to seal quite effectively and is quite resistant to damage if you don't go cave man on the torque.
Some people call them "dowty seals."
McMaster has them. Not cheap at $7 for a seal, but since it's basically a lifetime seal, won't leak and doesn't need much torque to seal, it's probably worth doing to just buy once, cry once. Especially if you are doing some kind of permanent valve thing instead of a drain plug.
Here's the aluminum flat washer that came on the Gold Plug magnetic drain plug. It's been used 4 times so far, and looks fine and never any signs of leakage.
