I'd like some opinions on changing the ATF in my camry.
Since you can't drain 100% of the fluid from the transmission and diff. would it be effective to drain as much fluid as possible, refill, drive for a day or two and repeat this process a couple of times to get the fluid changed out?
Also, which Dexron III should I use?
