- Joined
- Jan 6, 2005
- Messages
- 10,327
It was in my '00 GTI.
Oye.quote:
Would anyone care to offer up some opinions?
Do you know the HTHS of the Syntec 5W-40? I can't seem to find it anywhere...
which is a better trade-off - a 0W that will do better on cold starts, but shear more, or a 5W which will shear less, but perform less well on cold starts?
It doesn't sound like there is a good reason to switch from what I'm already using (Mobil 1 0W-40)...
Unless I'm missing something important that someone wants to clue me in on.
Tooslick, what is your comment on Doug Hillary's remark above that claims about Mobil 1 0W-40 suffering from excessive shearing are misinformation?
a 502 rating is nice to have (but not a must) and would like to stick to a 5K OCI, which oil do you think would be better than Mobil 1 0W-40 and why?
And whose personal recommendations did I decry?quote:
Originally posted by Audi Junkie:
On one hand, you decry the opinionated members' personal recommendations. On the other, you continue with an ambiguous line of inquiry that encourages it...because there is not much HARD data out there, certianly none that is hidden from your vast research of used oil analysis.
I have to ask: if these questions annoy you this much, why are you reading this thread?quote:
Oye.![]()
20+ Members give a reply, their personal opinion, and you appear to still be right where you started.quote:
I'm hoping that there might yet be some more nuggets that could be uncovered my turning over a few more rocks.
And I'm required to make a decision right now?quote:
The sludge issue in the 1.8T occurred only in North America. Keep in mind that most newer Euro versions of the 1.8T are actually equipped for LL service and have much longer service and OC intervals than their NA export brethren. The sludge issue in the 1.8T in the NA market was due toquote:
VOA/Audi screwed up with the sump capacity/OCI/oil quality specification on the 1.8T, and the problems and subsequent remedial measures evidence that error. These sludge-prone engines need synthetic at a minimum to survive. It's not the first instance where a manufacturer erred, and it won't be the last.
The question question you quote above was specifically directed at Volvohead, whom I quoted when I asked the question, because he seems to think Mobil 1 0W-40 is very sub-optimal.DDquote:
Originally posted by DD:
Did I say you wrote that? No. Did I provide a direct quote? No. The phrase 'he seems to think' should have clued you in that it was a paraphrase.quote:
I NEVER wrote that. You obviously can't read, or you read what you want into what is written.
Your question was what oils were BETTER than 0w-40 for your intended application. Mobil 1 0w-40 is a superb oil. But it has some OCI limitations, particularly the way you want to use it. The other oils are BETTER at longer OCIs.
Then you started shifting the target to challenge the answers.
I agree with Audi Junkie: your reasoning wanders and places the rabbit in the hat after you have been given good advice.
I am done with this thread.
Touche!quote:
Originally posted by wavinwayne:
So, DD, have you decided on an oil yet?![]()
The one concern I would have with GC would be availability. Rumor on the GC forum seemed to be that the supply is expected to dry up, and if you don't already have a stash, you may be out of luck.quote:
On a serious note, if you can find GC, I think it would be a perfect fit for your Audi. I'm currently running it in my VW GTI 1.8T & I love it.
DD, sorry used oil analysis not posted; I haven't been too active on this board. I'll try posting my next one in a couple months.quote:
Pushslice,
I agree the viscosity range isn't necessary here. We could probably get away with a 20W-30/40, if there was such a thing.![]()
Which synthetic 5W30 have you been using? And are your used oil analysis posted?
The supply of green GC is drying up, but it has been replaced by gold GC (which carries the same ratings as the green GC, IIRC). Unfortunately, we don't know yet if gold GC performs as well as the green GC. Only time and more used oil analysis on the gold GC will tell the full story. In the meantime, many of us are stocking up on the green GC when we see it.quote:
DD
