I've been contemplating an oil temp guage for the SS. Is anyone knowledable about where to mount the sender? I suppose the easiest place would be the oil pan drain plug, if they make a sender with that thread. But will that location reflect good oil temp readings? If not, then where?
Where does the corvette have its oil temp sender?
Also, I'm curious about M6 trans fluid temps, and was thinking of doing a 2nd guage for that. But I would want a much lower scale and was thinking of using a water temp guage if I couldn't find an oil temp guage with a scale I liked. What do you think? I figure the only two (easy) places to put a sender on the T-56 are either the vent or drain plug holes, and I'm not sure how much clearance inwards there is there. And what temps should I expect? I'm guessing 140-170F most of the time.
