Where to put jack stands on a 2015 Meriva B?
xsr
Hi there,
I own a 2015 Opel Meriva B. I'm trying to figure out where the front jacking point is to lift the front of the car. Also, where are the best spots to place the jack stands once the front is raised?
I've attached a video – I'd really appreciate it if you could help me out. Thanks!
That section with the holes is good, and the beam begind it for a jack stand. There's likely an indication to show where on the sill you should jack but even then they could get damaged.
If in doubt, jack on the subframe, where it's bolted to the car
