Originally Posted by MolaKule
Originally Posted by Nyogtha
So, in comparison, what about the market niche for products like Mobil 1 ATF and Pennzoil Platinum High Mileage Fully Synthetic ATF? These have fully synthetic base stocks and the fluid manufacturers recommend these for DexIII / Mercon applications with an in-the-bottle viscosity in the DexIII range.
Will these formulations maintain their operating viscosity longer than a currently available conventional DexIII / Mercon fluid, or will they lose viscosity due to shear just as quickly as conventional DexIII / Mercon ATF formulations?
Those that use the additive package that conforms to the old Dexron III(H) may have a slighty longer life, due to improved base oil anti-oxidation, but will not have the shear nor the friction modifier stability.
Some of the botique ATF manf. are using an equivalent Dexron VI additive package with their full synthetic base oils so those ATF's should show the same, if not better, long term stability. Of course, their prices tend to reflect this as well.
So the guiding factor for the retail comsumer as to which DexIII compatible fluids with synthetic base stocks and DexVI additive package is price?
What about products such as Pennzoil Platinum High Mileage Fully Synthetic ATF that didn't exist before 2005? It has a typical retail price lower than Mobil 1 ATF, but Mobil 1 ATF existed before 2005 IIRC.
Regarding the Brookfield vis specs, it appears XOM gets around this by using the term "recommended for DexIII / Merc applications" rather than "meets DexIII / Merc specifications". Otherwise the Brookfield vis specs would appear to be mutually exclusive with use of synthetic base stocks.
https://www.mobil.com/English-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-Synthetic-ATF
https://www.mobil.com/english-us/passenger-vehicle-lube/pds/glxxmobil-atf-dm
I'll add the only time I bought M1 ATF was at end of year closeout at Autozone for $2 / qt a few years back for a friend's 4T65E, it was the same price as Super Tech conventional DexIII / Merc at that limited time window.
