Yes, but most of those environmentalists are old and dying off.
We need to decide what the goal is. If it is the elimination of fossil fuels from power generation, we aren't getting there with wind or solar. Not only is their production and transport, most of which for solar occurs in China, heavily dependent on fossil fuels, but they aren't capable of producing process heat for example. If we are exclusively looking at power generation, wind can be complimentary to massive reservoir hydro (like Quebec) but most grids are not blessed with those kinds of resources and projects of that scale would be impossible nowadays with regulations. You can't just flood an area the size of Florida to make power now.
Here in Ontario, we did the wind and solar sideshow and it was a major flop. Wind produces grossly out of phase with demand to the point that its capacity value is so low it is basically useless. Ultimately, what was used to eliminate coal from our grid was refurbished and reactivated nuclear. We would also have new build nuclear if we hadn't wasted 10's of billions on VRE, which dramatically increased rates to the point where the topic became hypersensitive. We have a 5,000MW wind fleet that is most productive in the spring and fall, when our demand is the lowest. This results in that heavily subsidized power (rates, including curtailment, average $0.148/kWh) being dumped on the market for prices that sometimes go negative. It's the scam that keeps on taking. Solar was also insanely heavily subsidized, but it at least has the value of decreasing mid-day peaking requirements during the summer, though of course that creates morning/evening ramps that are covered by a mix of gas and hydro.
On the CAPEX and "cheapness" of offshore wind front, relative to a nuke, we need to be careful. The Dominion project recently was announced to have increased in cost by $2 billion dollars:
https://www.virginiamercury.com/blog-va/dominion-offshore-wind-price-tag-jumps-by-nearly-2-billion/
This puts the total projected cost for the project at just under $10 billion. You'll notice they cite a $1 billion "tax credit" for the project as well... Where's the one for Vogtle?
This project is 112,800 acres and consists of 176 14.7MW turbines; it has a nameplate capacity of 2,587MW, roughly the same as Vogtle. Anticipated life expectancy is 20-30 years. This farm is stated to increase consumer bills by $4/month.
Vogtle 3&4 on the other hand consists of two 1,117MW AP1000's; it has a nameplate capacity of 2,234MW. Anticipated life expectancy will be 60-80 years. At a cost of $25 billion, this plant is expected to increase consumer bills by $3.75/month.
The current capacity factor for Vogtle units 1 and 2 is above 92%. Offshore wind is somewhere around 40-45%. Ergo, Vogtle will produce >$18.2TWh/year, Virginia wind between 9 and 10; ~50% less. So, in terms of price per kWh, the projects are roughly the same. The nuke has double the CAPEX, but produces double the electricity. The nuke also has 2-4x longer lifespan. The nuke's CF also means it doesn't need backup nameplate capacity in gas gen. So, ultimately, which is really cheaper?
