The roads and land around there are full of radiation. The Russians drove on them contaminating themselves with the dust. Then we have Japan with a bit of an issue too. I am all for nuclear, but not that way.I talked to an engineer that had worked in the switchyard . He told me that the yard was nearly a square mile . Sounds like an exaggeration but I'm sure an open air 750kv yard is pretty **** big .
Agreed. It shows the reality of the situation and the application which isn’t greatWhile an interesting scenario, showing EV's being charged primarily with diesel isn't a glowing endorsement.
I didn’t, no worries as they say these days.Don't use this as a benchmark for how "EV" or "plug in" should be.
They are decent sized, but they aren't as big as you think they are. The section below the plant, after water, is where the switchyards were, I'll put it it in the picture:I talked to an engineer that had worked in the switchyard . He told me that the yard was nearly a square mile . Sounds like an exaggeration but I'm sure an open air 750kv yard is pretty **** big .
Offshore wind will be the dominant solution, far less harmful to birds (especially with how large and relatively slow the blades are). Not that many birds flying around a dozen miles or more offshore. Not to mention they are far more efficient as there is more constant wind than onshore solutions, and no infrasound concerns to local residents. The main obstacle is NIMBYs who don't want their view of the ocean ruined by some distant windfarms.Yes, Nuclear is the answer, to be clear for others who may not know, France announced a large undertaking to get new Nuclear plants built after previous administration was planning to reduce nuclear, they have gone the other way and extended the time line to shut down plants.
As it is right now, 70% of Frances electric power comes from Nuclear.
China and India blowing right past the USA too, the E/U is making plans to ramp up building nuclear plants.
The USA? nothing but Crickets. My last hopes were dashed right here in South Carolina, we had two new nuclear plants under construction, billions spent, construction stopped because of mis- management AND primarily incompetence by the reactor supplier Westinghouse/Toshiba.
Ok, onto wind power, to me is laughable, the same special interests that made it impossible to get nuclear power plants up and running endorsing wind power is laughable. Every oil spill we ever saw on TV for decades showed a few hundred birds or even a thousand birds wallowing and dying in oil. Yet, the media doesnt show photos of the wind farms and the 10's of thousands of migrating birds that are killed in the wind fields every year in the USA.. go figure .. *LOL*
(no politics)
Not even just driving through them, though that was a huge part of it, since they kicked up radioactive dust which they then inhaled- the worst is that they were digging deep trenches in the worst contaminated areas. It's worse than it sounds even, because the topsoil isn't the worst part. Lots of radioactive trees, the topsoil from the time, and lots of other equipment etc was buried in that area. Meaning that in the process of digging not only did they disturb the topsoil they were digging straight down into the place where some of the most contaminated waste was buried. Talk about idiotic, you're talking huge whole-body doses over extended periods.The roads and land around there are full of radiation. The Russians drove on them contaminating themselves with the dust. Then we have Japan with a bit of an issue too. I am all for nuclear, but not that way.
As if none of what they are saying is uncolored by political influence. There is no such thing as unbiased analysis.https://ieeexplore.ieee.org/abstract/document/9530709
Here. Instead of speculating or listening to the media and politicians. Read what the people who are going to have make all this nonsense work are saying.
Yep. Those windmills everywhere are an eyesore.The footprint of wind and solar far exceeds that of any other energy source.
As a kid I remember traveling through a stretch in Eastern Washington called Horse Heaven Hills. We actually did get to see wild horses in the distance. Something like that sticks with you.
Several years ago the wife and I traveled the same route. Wind farms and solar panels. No more horses.
We'll be in one or the other in the coming years.
They won't be around for long if sea level keeps rising.The Maldives might have fit their model for a country that would benefit greatly from EVs. However they routinely get cyclones going through there and just in the past few weeks they had a bad one. Infrastructure takes a real beating there.
just what type of technology + investments does one need to come up with to create the path to a $9 per month bill?I live in CA; no one told me not to charge my car. Can you identify your source? Thanks!
By the way, my electricity bill runs about $9 per month.
If nothing else I'm sad because I actually have seeing the exclusion zone on my bucket list, thanks to the STALKER games, being a history nerd and a nuclear supporter and the whole.... situation... makes it unlikely I'd be able to visit for a long time. Truly first world problems however.
As you can see in the below videos, the surface level radiation is high but not exactly dangerous for shorter periods. Going a meter or so off the road the radiation level climbs extremely fast but again for short periods of time not deadly or particularly harmful (still in the microsievert/hr range). But kicking up dust and breathing said dust in, and then digging extensively in trenches for days/weeks surrounded by radioactive material is near suicidal. The inverse square law means that if there is a piece of highly radioactive material the further away you get from it, the lower the dose. This means you can hold a piece of radioactive material for a short time and be totally fine, because it's most likely only a high dose on a small part of your body. Cumulative dose is what matters. This topic honestly deserves it's own thread.
feels like we very close to Mad Max than ever beforeMaybe!
Of course, I can't decide which of those two movies I like better!
Well I think he said he paid 17k for it. So if it has a 20 year life, then you amortize that over the life of the system. You really need to normalize by figuring out how much it would be with a no money down analysis which is basically what a regular monthly electric bill is. If you put 17k in the stock market and average 10% over 20 years, is your bill really $9 a month? On the other hand, borrow 17k and amortize it over 15 years at say 3% back in the day, you're still paying $117 a month for 15 years.just what type of technology + investments does one need to come up with to create the path to a $9 per month bill?
Totally can believe it. Just wonder how much and how long it took to accomplish?
I did some work to my present home over the last 22 years to knock my power bill in half with just insulation and shade from
oak trees and double windows. People can find saving in lots of ways if they just try. Congrats on your accomplishment for sure.
It's gotta come from Nuclear or Natural Gas as coal is phased out. Gonna take 25 to 40 years for a smooth transition. Toyota Camry recharges it's battery by braking, so, no Electrical Grid use. Toyota hybrids are a nice transition vehicle. Pun. JmoI see that many are excited about EVs, I can understand part of it but I myself stand by my thoughts that it will not be possible for EVs to come close to replacing gasoline vehicles for at least 20 years, more or less I can see EVs maybe getting to a saturation point of 20% of new vehicle sales, if that much, I think maybe closer to 10%. I think once people see the cost of charging them AND the fact that we do not have the power plants and infrastructure to carry the electricity to everyones home to charge the cars.
So where is the power going to come from to charge these cars? We barely have enough power in the USA to run our home air conditioners at any time of the day.
Until people wake up to the fact that we need nuclear plants, its just not going to happen.
Source = https://www.cnbc.com/2022/04/04/map-of-nuclear-power-in-the-us-see-where-reactors-are-located.html
Both equals for meMaybe!
Solar panel systems have been big in CA and Silicon Valley for a long time. Energy costs are high and there is lotsa sun. We live in a small town, Los Gatos, at the foot of the Santa Cruz Mountains. Solar projects are expensive, but have come way down. In later 2017 I started to get serious; Costco Sunrun was offering a compelling story. I ultimately contracted with Infinity Solar. The new roof and panels were installed in Feb 2018.just what type of technology + investments does one need to come up with to create the path to a $9 per month bill?
I wouldn't use stock market as the opportunity cost, it can go up and it can go down, so a mortgage or HELOC interest would be more realistic. Assuming it is today's 4% rate, that 12k would be about $72.72 a month in the bankrate amortization calculator.Well I think he said he paid 17k for it. So if it has a 20 year life, then you amortize that over the life of the system. You really need to normalize by figuring out how much it would be with a no money down analysis which is basically what a regular monthly electric bill is. If you put 17k in the stock market and average 10% over 20 years, is your bill really $9 a month? On the other hand, borrow 17k and amortize it over 15 years at say 3% back in the day, you're still paying $117 a month for 15 years.
