It's been VERY cold here in NJ over the past week or so and I thought yesterday would be a good time to check my coolant level. Well, the coolant overflow tank was almost empty so I had to fill it all the way back up to the full mark. Had to use half a jug of Prestone. I looked all around the engine compartment, including the overfill tank, all around the hoses and radiator and found no leaks at all. No drip marks on the ground either. Radiator is full. Would antifreeze just evaporate in the system? I've been using the 50/50 pre-dilluted stuff from Prestone. Maybe this stuff contains more water then antifreeze…...it does pour out green though. Any idea's?
Thanks.
Thanks.
