When would you not want an ADBV?
Originally Posted by jayjr1105
Originally Posted by CT8
What is the filters mounting position?
Vertical
[Linked Image]
It has always been my understanding that even a vertical base plate facing up filter could use a fully functioning ADBV. The filter would certainly stay filled regardless, but that ADBV could be holding some oil inside the engine too.
Looked up Wix/(NG) filter application for topic Mazda Slyactive engine and found several google images of the 5/7002 filter. As noted, same as the factory Mazda filter, no adbv for specific application. So like the Fram EG/(TG) shown earlier for GM applications, they match the factory part with no adbv in replacement filter for Mazda. It would seem imo if maintaining oil in galleries 'these specific' applications critical, no less so from factory as opposed to subsequent service. Again, as ACDelco and Mazda off the shelf filter would indicate, having one even where not factory spec'd works too.
Not an easy thing to be on this website … but I'm predominantly a long term GM owner … don't recall any standard oil filters without an ADBV … and majority of them mounted base upwards
The Cruze is the only GM I have owned with a cartridge
Originally Posted by Sayjac
Never seen nor heard of PC vehicles back filled at factory reason for no adbv. Would need specific example(s) with authoritative citing and relavance to topic Mazda and GM application. Answer as given to OP with links and examples accurate as posted. The topic Mazda and GM vehicles with sourced reference from Fram rep confirmation of those applications having no adbv.
It was a special General Motors application like a police Interceptor V8 or something. Been a long minute since I thought about the details but there really was such a thing per a discussion when I was a NAPA counter-boy in the old days. The first-fit filter had no ADBV but the dealer-recommended replacement filter did.
Regardless....forget the science & theory. There's only 2 ways about it:
1. If the first-fit filter from the factory doesn't have the ADBV, there is no problem with your aftermarket or dealer-service filter if it does have the ADBV.
2. And if the factory first fit filter is equipped with the ADBV (or your manual tells you to use a model which does have the ADBV), you use a filter with the ADBV.
The AC Delco PF61 in 2004 did not wear an ADBV. It wasn't until the GM bankruptcy around 2008 that it did show both a PF61E and an ADBV in the PF61.
Quote
... If the first-fit filter from the factory doesn't have the ADBV, there is no problem with your aftermarket or dealer-service filter if it does have the ADBV.....
Which is basically what my initial post says. I prefer to use the term factory filter ie., filter that comes from the factory as assembly line engine part.
Whether there may or may not have been some undocumented exception, doesn't change the main point. As prior noted and linked, the GM ACDelco off the shelf filter(s) that replace the no adbv GM factory filter(s), have an adbv. That even though the Fram EG/TG equivalent has none.
