Originally Posted by madeej11
Originally Posted by UncleDave
Originally Posted by jayjr1105
Originally Posted by CT8
What is the filters mounting position?
Vertical
Mounted like this the filter will not drain dry but basically sit full of oil till next startup.
ADBV not remotely needed in this orientation.
UD
Agree with UD. How would the ADBV in a vertically mounted oil filter at the bottom of the engine stop oil from draining from the galleries? Doesn't make sense. I would say that in this case it doesn't really need one. Basically it's to stop the filter from draining dry when mounted other than in a threads up vertical position.
The oil in the galleries is ABOVE the oil filter. Any oil above the filter will want to drain down until the head (elevation) pressure above the filter is equalized.
Vertical
UD
