OVERKILL
$100 Site Donor 2021
I think this bit varies depending on who is doing the test. I'm not an expert on this, just have used the data before when comparing heads and was aware that it's pretty standardized for the most part. This variability is why you'll find slightly different data for the same head. You'll often see "with pipe" or "no pipe", which indicates whether they've used a pipe designed to simulate an intake runner or not (and I assume an exhaust header if doing the exhaust side).Thx; I am currently researching it, have viewed several articles... but:
i) there's an intake snorkel for the cylinder head intake port that aims to reduce inlet losses evident with a sharp-edged inlet...
There's a cylinder bore adapter for various heads, you can see them under the accessories section of the product catalogue:and presumably there is a similar snorkel that starts at bore diameter of the cyl head and presumably flares out a lot...
The idea is to simulate the bore the head would be fitted to.
This sounds like a very manual setup, most of this stuff is automated with the SuperFlow units. Here's the manual for one:then you start with air pressure measurement in the quiescent area outside of the inlet snorkel, and you adjust it to 14.696 PSIA... one std atmosphere, and you adjust the pressure of the outlet area (in a quiescent area) to 28" WC (just about 1.0 psi) LESS than the inlet pressure... to about 13.696 PSIA... and then you measure airflow at various lift values.
The computer basically handles all of that once you set your parameters. So, for the 28" of water calibration, you just choose that in the software.
And yes, once the unit is setup, you repeat the test, each time changing the lift, to get the flow figures for each of the standard lift points, which are usually in 0.050" increments.
Sounds like it, but I'm not an expert of running this stuff, I've just used the data previously.Do I have this more or less correct? Test pressure (inlet) 1.0 std atmospheres, delta P across cylinder head: 1.0 psi, meas in CFM (converted to std temp and press (STP).
The unit has both air temperature probes and barometric pressure sensors. Thus, all the results are corrected to a standard so they can be compared. I'd recommend reading section 7 (starts on Page 63) of the above manual, as it goes into FlowBench theory and mentions standardization (correction) if you are producing results designed to be compared broadly.Haven't thought about air temps, here.
Well, the two I presented above are intake/exhaust, and just the peak numbers. There is usually a table, which, if one was feeling motivated, they could plot to get a flow curve.What, typically, are the two values given?
