Hello folks,
I am in the process of changing transmission fluid of my 2006 Sentra. The capacity of this engine (RE4F03B) is 7 3/8 qt. In the changing process, I replace 4 qt of fluid. I plan to do this replacement 3X (more if required).
I considered changing ATF because I have never changed it (The car has 103,000 miles on it) and the car jerks between 1st to 2nd gear. I am not too sure if this is same as the shudder. I have changed the fluid once and the jerk reduced a bit but after 10 days its back. I plan to change another 4 qts in 10 days. Should I add Lubegard then or add it during last ATF (3rd) change?
Thanks in advance.
Thanks in advance.
