When searching Walmart, how to eliminate searching on a previous car?
Suburban Washington DC
Not sure if I 'splained it correctly, but I'm searching Walmart for 0W40 but the results say, there are none, which is obviously wrong as they have plenty of that stuff, but because I previously searched for something for a 2020 Corolla, Walmart thinks the 0W40 is for the Corolla. How do I eliminate the previous 2020 Corolla from the search results? So much for AI. Absolutely nothing happens when I hit the green check mark to uncheck it.
Click on the "Change" oval button on the right side of 2020 Toyota Corolla box and select "Remove Vehicle" in the bottom left corner of the pop up window.
I do it in private mode. Same issue.
I run into the same glitch as atikovi and ^this^ is what I end up doing too. If there's a way to unlink a vehicle, I haven't found it. On the other hand, instead of getting annoyed at how poorly WM has this, I just flip to private mode and solve it (for me).
