I have a 2009 Lawn Boy self-propelled mower that kept stripping the drive wheel gears. The pinion was metal, and the wheel gears were plastic. I thought it might be a metal/plastic issue, but it turned out to be an alignment issue. The wheel mounting plate was toed-in slightly due to horizontal pressure being applied by the height adjustment lever. This caused wear in the bushings and bearings which over time caused the mounting plate to toe-in. If you disengage the height adjuster all the way down it relieved the pressure and pinion/gear meshed correctly. Of course, you cannot use it like this, so I determined that if I could move the plate in the front out slightly and keep it there it would work. This is what I did. Because the wear on the wheel gear teeth was only on the outer edge, I was able to use the original wheels longer. After applying this fix, I never had another problem. Hope this helps someone else.
