I’m hoping that my truck only needs the tires balanced, which I will be getting this upcoming Tuesday (Getting 2 new tires), but just checking.
I have a 01 Chevy Silverado 2wd with 91000 miles on it. It’s been a great truck on lots of adventures. I’ve been monitoring the tires, like all good owners. I had 1 tire replaced this spring, and figured 2 others (both of the fronts) would need replacing this winter, and I’m about right (The irregular replacement of tires is due to getting 2 separate punctures (resulting in replacement) flats on separate trips to Death Valley, roughly a year apart.).
But 3 weeks ago, I started to notice the steering wheel shake at speeds up to 40 mph (worst at low speeds). Today, while looking at the tires that are set to be replaced (Wearing evenly, for the most part). I noticed that the right front tire had a section on the outside that had worn past the tread.
Could this just be a balancing issue, or something issue (Alignment, maybe parts needing replacement), and if so, what?
Thanks.
Thanks.
