I have had an ongoing problem with the back end of my car getting loose, mainly on the highway. It will sway back a forth so much so that it is rather disheartening. It had a bent lateral rod which was replaced. However, I took it into the shop to have the alignment checked out and everything but the front wheel camber angles were o.k. The camber on the front left wheel was 1.7*, right wheel -0.5*, with spec being 0.2*-1.2*. The guy said there is no way to adjust the camber settings and I would have to try replacing either the strut assembly or the control arms.
My question is: Is there in fact no way to adjust the camber on my car, and do you think his suggestions are my best bet?
The car is 5th generation Chevrolet Monte Carlo.
Thanks
Thanks
