Look, you do NOT have to totally drain what's in your cooling system. I'm not sure waiting in your area until the weather warms is a great idea, either. As labman already posted, antifreeze concentrate will freeze SOLID at 0 degrees F. (Can you say, "cracked heads and/or block"?) Get one of the Prestone antifreeze testers to see where you are percentage-wise with the present coolant. Drain and CATCH the present undiluted coolant concentrate from the radiator, and top up with distilled water and some of the caught concentrate to achieve a 50/50 mix. The rest of the concentrate you caught can be transferred to a clean, sealable container and saved for future use - no sense wasting perfectly good, nearly new concentrate. Personally, I'm neither in favor of screwing around with additional chemistry that may or may not be compatible with standard coolants and seal materials, nor have I ever had occasion to feel I needed to do so. I'm sure others will disagree, but then, they're not paying the costs involved with my car maintenance, either. Do whatever you feel is best for your ride.
