Originally Posted By: callbay
I went to Wal-mart and got a 5 quart bottle of SuperTec 5-20 oil and a cheap Fram filter as they did not have a Purolator Classic in the size I needed for the mini-van. I changed it cold so I did not have to start it with the old oil. The old stuff was pretty bad. I put some of it in a glass container and it stuck to the wall of the container with a thick coating. The filter was a Champion brand cheap filter that looked like the old Wal-Mart Super Tec's. It is about an inch shorter than even the Fram is. Don't know how many miles were on the oil.
It did not seem to help when I started it with the new oil and I let it sit there and warm up which did not help either.
It was strange that the knocking would sometimes almost go away and often changed its sound. I called the widow of the owner and she said they drove it a week with the knock and then parked it. If only they had changed the oil more often.
The noise seems to be in the top of the engine. Does this sound like a lifter gone bad?
What would you recommend doing at this point?
Thanks a ton.
Grampi pretty much summed up what I'd do. Read his comments above.
Thanks a ton.
