I did some posting and some PM's. Replies were everything from "use it 100% according to instructions and it'll perform as advertised" to "use it as parts cleaner"
I have it, doubt I could sell it, want to use it. Also plan on doing double Auto-RX.
What are your thoughts as to what order to do them in? I'm inclined to do Amsoil flush, then the 2 Auto-RX treatments (both with used oil analysis which will be posted) I don't want ANY of that flush in my extended drain stuff at the end.
To add a new matter, I have a by-pass oil filter. When should it be changed? Before any of the above 3 treatments? After? Both? (replace something designed for annual replacement in a 6 litre engine, used 1 month in a 1.6??)
Thanks MUCH!
Rob
Thanks MUCH!
Rob
