what's in your oil stash???
Louisiana
I must admit, after reading these forums for years I have gathered quite a collection of oils. Between my dodge truck, my girlfriend's kia, and the random lawn equipment I take care of I have developed quite a stash of oil bottles of this that and the other. Just curious what you guys keep on hand at all times? I pretty much always have 30w for the mowers and 10w30 for the truck, I also keep a gallon of cheap transmission fluid for flushing out the crankcase of engines in friends vehicles that are often way over due for an oil change. What would you guys consider your typical inventory for around the house? How about in your vehicle tool box, do ya'll always carry extra for the "just in case" moments?
I have donated quite a bit of mine and am down to 1 brand/type for the Explorer, 4 brands/types for the F-250, and 1 brand/type for the Brute Force 750:
Explorer:
- Mobil 1 Advanced Fuel Economy; 0W-20 (50 Qts)
F-250:
- Chevron Delo 400 LE; 5W-40 (10 Qts)
- Chevron Delo 400 LE; 15w40 (40 Qts)
- Mobil 1 Delvac ESP; 5W-40 (80 Qts)
- Shell Rotella T6; 5W-40 (16 Qts)
Brute Force 750:
- Quaker State Defy; 10W-40 (10 Qts) - will switch to the same oil as the F-250 when the QS runs out.
I have a considerable quantity of 10w40 Peak I got on clearance that I save for "beater oil".
I have a bunch of 10w30 that will work in my camry in summer, mostly maxlife and kendall.
A bunch of AFE 0w30 for my MILs buick (dexos) and wife's HHR.
Five different brands/ kinds of antifreeze... Neon took G-05, Camry Zerex Asian, F150 Green snot, and HHR dexcool. I also have universal: looks green, acts like dexcool. Plenty of ATF too.
Various oils bought on special: Some Super S 5w30, a jug of Mobil 1 10w30 high mileage, a gallon of Mobil 1 Turbo Diesel Truck for the generators, jug of Chevron 5w30, and a few other miscellaneous quarts. Not much of a stash, really. I do have a nice little pile of CarQuest Blue oil filters that I got from the Rock Auto blowout, though.
Ok, here it goes:
5qts Castrol Edge 0w20
5qts Mobil 1 Advanced Fuel Economy 0w20
4qts Castrol High Mileage 5w30
4qts Castrol Edge 10w30
4qts Mobil 1 10w30
4qts Castrol High Mileage 10w40 (just in case)
1qt of frankenbrew from all the left over bottles I drain the residual out.
Three 5 quart containers of Pennzoil Platinum 5W-20
One 5 quart container of MaxLife Full Synthetic 5w30
One 5 quart container of Mobil Super High Mileage 5w30
Two Motorcraft FL-820S, One Purolator Classic L24651, One FRAM Tough Guard TG2
A quart of Platinum, a quart of MaxLife, a quart of Castrol Edge & a quart of Mobil 1 are also around for top ups. My oil stash will be depleted by spring. I try not to keep much around.
Mobil 1 Extended Performance 0w20 and 0W-40 (blending for winter / summer) for the 3 newer vehicles.
Valvoline MaxLife 5W-20 and 5w30 for the 2 older vehicles.
RP HP 0W-20 and Castrol Edge 0W-20 for the Outback. Mobil 1 5w30 for the Alero.
I kind of backed off from building my stash when I realized that I had almost 3 years worth for the Outback. Now I'm down to about 2 years supply. And I'm getting a little tired of the Alero as my commuter car, so I'm only keeping one oil change at a time on hand. That way I won't have a large stash left over if I change rides one day.
I have too much. Have to stop buying oil at least for PCMO oils.
Oil
4 5G Chevron Delo 400LE 15W40
4 1G Chevron Delo 400XLE 10W30
1 1G Chevron Delo 400LE 15W40
7 5Qt Pennzoil Platinum 5W30
6 5Qt Chevron Supreme 5W20
5 5Qt Pennzoil Conventional 5w30
2 5Qt Klondike Syn Blend 5W20
2 5Qt Pennzoil Conventional 10w30
5 5L Castrol 0W40 A3/B4
2 4.4L Castrol 5W30
2 4.4L Mobil 1 Advanced Fuel Economy 0W20
1 5Qt Quaker State Conventional 10w30
12 1Qt Kendall GT-1 Full Synthetic 0W20
12 1Qt Valvoline All Fleet Plus 15W40
2 1Qt Ford Motorcraft 5W50
2 1Qt Quaker State ED 15W40
1 1Qt Amsoil AME 15W40
1 Qt Castrol Syntec 5W20
Transmission
2.5 5L Valvoline Maxlife ATF
1 5L Mobil ATF+4
1 1G Shell Spirax S6 ATF A295
.5 Qt Quaker State Semi Syn ATF
Gear Oil
.9 5G Klondike Synthetic 75W90
3 1Qt Klondike Synthetic 75W90
4 1Qt Lucas 75W90
1 5L Shell Spirax 80W90
3 1Qt Castrol Hypoid 80W90
1 1G Smitty Super S 80W90
Miscellaneous
34 1Qt Kendall 30wt Non Detergent
5 1Qt Castrol 30wt Non Detergent
4 x 5Qt Pennzoil Ultra Platinum 5w30
1 x 5Qt Castrol Edge 0w40
2 x 5Qt Pennzoil Conventional 10w30
Oil filters
3 x S2000 oil filter
1 x Fram Ultra XG7317
1 x Mahle OC 330
4 5qt Pennzoil Platinum 5w20
2 5qt Quaker State Ultimate Durability 10w30
2 5qt Mobil Super 5000 5w30
16qt Pennzoil Ultra Platinum 5w20
13qt Castrol Edge Gold 5w20
16qt Napa Synthetic 5w20
12qt Pennzoil Conventional 10w30
20qt Peak 5w30
2qt Napa Conventional SAE30
2qt Pennzoil Platinum 10w30
1qt Mobil Super 5000 10w30
4qt Peak ATF
