I ran royal purple grease in an 3500 truck, got rid of truck with 230k miles, factory ball joints, factory steering components, all with RP grease.Royal Purple is a really decent grease,,only place is to order online,no stores around here have ,can get their pcmo engine oil at various places .
Timken grease is good,but for the money i still would recommend Mysyik Jt-6 red or blue semi-syn. grease, ( easy to find) ,there are many good greases on the market,, also to note Mystik makes calcium based grease too,,so does Amsoil. if want to try something different but has a good following among the farming and construction community go look at Cenex oils and greases,,i believe Axel makes their grease ,which is some exceptionally good grease. Kendall L-427 is a worthy mention in the automotive crowd.
Some BITOG guys use M1. Vavaroom uses an M3?Cal. 45
very good choiceMy grease gun finally ran out. When I pulled the tube, I discovered that (for the last few years) I've been using Slick 50 "1" Grease. Supposed to be the "1" grease for everything. It's sorta a green color.
So, in goes a tube of red Mystik JT-6 High Temperature Grease.
