that will help clean [censored] out of the carburetor? Normally I'd just pull the carb apart and clean it up but the engine runs fairly well, just that it needs half choke all the time, I can never go full lean or the engine oscillates like crazy. Plus there's weird tools required to pull the carb apart and it's buried under multiple guards, so it'd be easier if I could run some fuel system cleaner through it. Just not sure what would be best to use
