What to look for in cartridge filter?
Kentucky
Bought a vehicle that has a cartridge filter and looking for good replacements as I don't intend to use OEM. Last time I owned a vehicle with a cartridge filter was around 2002 when they first came out (VW VR6 engine) and you only had one or two options... Now I see there's plenty to choose from, all the way from $2 Rockauto Ultrapowers, to $15 brand name ones.
Is price a good indicator of quality? Looking at product photos, some of the cheapie filters look to have more substantial media than the high dollar ones. Are efficiency ratings usually advertised? I can't find anything of value on Rockauto's website that might help me in quest to find a filter with the best bang for buck ratio. What should I be looking for in a good filter? Any certain brands better than others, or are most created equal? I can certainly see there are less variables with these than canister filters; I suppose it all boils down to the filter media they use, is what I assume. The application is a Kia/Hyundai 3.3L V6 GDI engine.
If filter efficiency rating is important, then only look at filters that have an ISO 4845-12 efficiency rating.
... Any certain brands better than others, or are most created equal? I can certainly see there are less variables with these than canister filters; I suppose it all boils down to the filter media they use, is what I assume. ...
That's right. Essentially you want the same characteristics you'd want in the media pack of a canister filter. Price is not necessarily proportionate to quality; I've seen some expensive mediocre ones in the size I use (not the same as yours), and well-made moderately priced ones. One not-so-obvious point to watch is that they have proper dimensions and geometry so they fit in your housing without collapsing or bypassing oil around the ends.
Originally Posted by danez_yoda
FRAM is fine. EG TG or XG your chioce.
I am a big fan of Fram spin on can oil filters but truthfully their cartridge oil filters are not something I would consider using, too many issues reported.
For my Mercedes engine I would normally get a Mahle filter from Blauparts, recently I used a K&N filter and thought it held up very well. Mahle (or maybe Mann) will likely have the highest efficiency or at least higher than K&N.
Originally Posted by Danno
Why not use OEM filter? IIRC, its a Mann filter.
It just works.
Yep - the OEM or OE supplier ones are well-made and don't exhibit as much crushing or collapse issue as aftermarket ones.
I have used several brands in my wife's 2014 Chrysler T&C. Brands include K&N, Wix, Mobil 1 and Mopar. I have stuck with Mopar (OEM for me) the last several changes as it seems to be the best price and available at Walmart or Farm & Fleet in my area. The Mopar filter structure seemed to hold up better than the Wix. The Wix cartridge showed deformation in the pleats when I used it. The Mobil 1 and K&N seemed to be good but more expensive than the Mopar in my area. I vote for OEM due to cost and quality given my experience.
The napa platinum line doesn't cover many of the cartridge styles, unfortunately. The Gold that fits my 2.7 Ford is still 18.00. Sorry, not adding much to the conversation, I guess, rather lamenting about lack of cartridge options in the upper lines.
