Ok,,let me start by explaining.For all intent and purpose,the engine that is in my S-10,is a circle track engine,that's what it was built for.It's a 1st generation Chevy small block,with double hump heads,,,that being said,,it has the old style valve stem seals,which are nothing more than an o-ring.I know that this situation needs to be remedied,,I just don't have the money at the momment.It does use oil quite a bit because the seals,,well,,they don't seal,,,and because of this,,I am always changing plugs because they are fowled from oil,so on and so forth.It is a high horsepower engine,that I have made streetable and I drive it on a daily basis,it also is an old school,flat tappet engine with a fairly high lift cam.What oil should I be using.At first I was using 20w50 Spectro Racing oil because it supposed to have 1800ppm's of ZDDP,,Ok,,I listened to all of the hype,,now,,,after reading all of your posts,,I am beginning to believe that this might have been a huge waste of money.So I have switched to 15w40 Rottela with a ZDDP additive.I have definately notice that it is starting better and even running better.I guess what I am asking,,,since I have to constantly ad oil to maintain the proper level,,,what would you recommend I use.I obviously want to take care of the engine,but if I don't need to be spending a lot of money,,,what would be the best direction to go in.I have considered just switching to Brad Penn 10w30,,because it would be light enough and it also has the ZDDP that I need,,,but I am still in the dark about what would be correct.
