I am working with pure (about 91 percent straight chain, about 7 percent same C and H count but not straight, about 2 percent other C H molecules close to chosen) hydrocarbon molecules C12 H26, C14 H30, C16 H34, C18 H38. Because each of these are fairly pure they have a narrow range of temperature for the melting point.
In actual uses, two of these are blended together to get a desired melting point temperature.
Initially, a section of containment is exposed to temperature far enough below melting point to create some wax and avoid supper cooling problem. What I am working with is the viscosity of the oil in the rest of the containment. Data is needed on viscosity for the temperature range where these blends of oils thicken up, to where they become wax.
Is there anything normally used to measure viscosity and temperature while oil turns to a wax?
What I really require is something that allows me to express the viscosity in percent of change, and possibly in percent of change of flow when simply powered by gravity.
Also, is there a lab that could do this?
