Hi,
I do not know where I should post this question, nevertheless ...
I bought myself a barrel of engine oil (208 l, 55 gallons). Its a Mobil Delvac XHP 10W-40 with a MB228.3 specification and ACEA E3/B2. I will need oil from that barrel 2 times a year and in between I don't want any oxidation to occur or humidity entering the barrel.
What type of pump system would you recommend for my needs? A rotary pump? A siphon pump? Anything else? Should I always remove the pump and close all lids again? Of course I'm looking for the least messy solution - and it should be as simple as possible :-). Are rotary pumps fully airtight?
Lucas
