What oil for 2 different lawnmowers?
Arkansas
I have a old Snapper rear engine rider. It has a 10hp Briggs on it. Should I use like a HD30 or 10-30 or does it really matter?
I also have a Craftsman with the 26hp Kolher Courage on it. What oil should be used in it?
Originally Posted By: Honda2003
Is SuperTech just fine or do I need like Castrol GTX or something?
Super Tech 10W30 would be fine.
Kohler recommends 10w30 or 30W - just like others have recommended. super tech is fine. I also would not hesitate to use 15w40.
Usually what I use. Home Depot is selling Shell 10-30 for under $3. Good oil for a cheap price.
Originally Posted By: krismoriah72
I use 5w40 Rotella in all my OPE and fun machines.
Same here. Getting some excellent life out of 4 different engines, the oldest being circa 1995.
For my Snapper rear engine rider with 12.5 hp B&S I use a synthetic 5w30.
From B&S website:
"A synthetic oil SAE 5w30 is the best for very cold temperatures of -20 to as high as 120° F (-30 to 40° C) providing the best protection at all temperatures as well as improved starting with less oil consumption."
I don't think they have put a 10hp Briggs on a Snapper mower in 30 plus years. That engine is NOT a candidate for synthetic oil. HD30 is what I would run in the old Snapper for sure!
Other engine, if newer and in good shape would get the same HD30, Rotella/Delo 10W30, or any synthetic 10W30 if it were mine, considering your climate.
I would side with a HDEO CJ-4 10w30 as well. Mystik is good along with the other brands. Farm and home type stores, at least in my area, carry Mystik at very good pricing. CJ-4's generally have more robust add packs and meet API SM class as well. CJ-4 requires a >3.5 HTHS as well. My JD Z445 gets the same CJ-4 10w30 that my semi truck gets and my compact tractor gets.
