Correct. 6MPG for a Detroit Diesel. Especially going 70MPH.If it's got a 2 stroke Detroit green leaker you might see 6 mpg.. a 4 cycle Cummins may get 8.
I was just going to post the same link, the Vermont DMV makes it easy to find that sort of thing.
Not to mention that given proper maintenance, that Detroit will likely still be running in another 50 years. It’s doubtful any EVs will ever see a 50 year lifespan.That bus has likely done more work than a thousand EVs, and likely has about the same total “pollution”.
Throw some of the dimpled pistons I linked a whitepaper to in a different thread, and it would likely be cleaner per unit of work.
The 62 Pete I had is still rocking its original nt280 b Cummins.Not to mention that given proper maintenance, that Detroit will likely still be running in another 50 years. It’s doubtful any EVs will ever see a 50 year lifespan.
That’s exactly what it reminded me of; a Crown. I was a firefighter in the 70s and Crown also made fire trucks that were absolutely gorgeous.It is most certainly not a GM. It is a Crown Coach made in Chino, CA. That is an oddball, they didn't make very many old bodies with the rear engine. That one is most likely 1988-1989. Rear engine Cummins C8.3 with an Allison MT 647. Air suspension was available on both ends. We had one in the fleet where I worked. We also had real Crowns with Cummins or Detroits mounted horizontally under the middle. Stick and auto. You will never find a better built school bus.
My dad was a firefighter for Los Angeles County through the 70s and 80s. His station 95 was one of the last to have their Crown Firecoach replaced. I have the 95 number plate on the wall here. In 1958 County had Crown custom build 2 short buses for crew transport. They had Hall-Scott 504 ci ohc gas 6 cylinder engines. My dad drove one with a load of trainees on occasion. One bus survives today beautifully restored, I have had the chance to wrench on it and drive it. The rumble of the Hall -Scott under the floor is amazing.That’s exactly what it reminded me of; a Crown. I was a firefighter in the 70s and Crown also made fire trucks that were absolutely gorgeous.
I rode in a greyhound bus once. My dumb arse managed to sit where the engine was. That unique sound got real old real fast.Drove an old Mack with an 8V92 just to move it for some cash …
(owner had no drivers available and I had a CDL) …
They did sound unique …
Your Gillig may have been Cat powered, most likely the 1160, a precursor to the 3208. Transmission was an old rough shifting Allison. We had a 69 Carpenter transit in the fleet with a Ford gasser up front, MT 42 cast Iron Allison trans. Giant turd of a bus but it looked cool with its compound curved windshields. We also had 5 Gillig Phantom transit buses in the fleet. De rated Detroit 6V 92 rear engine with the MT series Allison. Dogs to drive and crappy bodies. Those things leaked in the rain from new. Premature rusters too. Electrics for the heaters was undersized, I was constantly replacing that portion of the fuse block. Nice driving on the road with air suspension front and rear but nowhere near as stout as a Crown.My elementary/junior high school district ran Gillig buses (made in San Leandro, CA) back in the 60's and 70's. Until the school district made us find our own way to school. I have no idea what kind of engine was in the back. The later buses had what I'm assuming was some kind of semi automatic transmission. The shift quadrant had more than a few forward ranges. They were oddly marked like 1-4, 2-6, etc.
We have a good friend that works at Gillig (now in Livermore, CA). Yes, she works on the assembly line.
There is a guy that brings a 12v71 to the truck show every year and I enjoy hearing it. When I get tired of it I can walk away unlike being stuck on a bus.
Oh another thing. If that bus has the 2 stroke Detroit diesel it requires a sae 40 oil. Multi viscosity oils like 15w -40 are not recommended and can cause premature engine wear.
The oils for them are getting scarce. At least here. Chevron delo100 is one brand.
Those engines were banned in my state 30+ years ago! We still have one at my work somehow. I cannot get the correct oil for it from anywhere.Rotella T1 40 wt
Delo 400
Delvac 1240
...are all out there, you might have to go to the local oil company jobber to get them, but it's not that hard to get. The 2 strokes might not be as common as they were say in the 1970s, but, there's still many in service around the world. I don't think CF-2 straight 40 is going away anytime sooon, sure, you can't buy it at Walmart or Autozone, but it's out there.
The straight 40 vs 15w40 in light of, Detroit having had discountined these engines for OTR applications in 1995, would be an interesting side topic for BITOG discussion. I mean obviously Detroit is not updating recommendations for these engines at this point in time. The DD 2 strokes require low ash oil as to not foul up the airbox, but that's pretty common nowadays with the modern emissions controls. So what makes the straight 40s so much better with all the associated dire warnings? Perhaps it's the HTHS? I note that Delvac 1240 has an HTHS of 4.6, yes the PDS is still out there.
PdsDetailsPage
Mobil Delvac 1220, 1230, 1240, and 1250 are heavy duty, diesel engine oils formulated from high performancebase oils and a balanced additive system of ashless dispersants, metallic detergents, and inhibitors to control oxidation, wear, corrosion, and rust. They are used in a wide range of...www.mobil.com
So what 15w40s are out there with an HTHS of 4.6 or above? I note that Amsoil ADP 15w40 has an HTHS of 4.7, sulfated ash of 1.0% , and is recommended for CF-2 applications.
Any other diesel oils with high HTHS out there? I noted HPL makes a 20w50 for diesel applications that has 5.3 hths.
and fuel.A new diesel pusher is $150K and up. Money saved will buy a whole lot of parts.....and weed.
