No my workplace.You have 208 3 phase at your residence?
Maybe 50 y ears ago the brought a Power Plant on line by synchronizing the frequency. Those days I believe are long gone (in the U.S)Its not the voltage it's the frequency.
Drop below 59.6hz and the clocks start ticking. They have 20 minutes to increase frequency or power plants start disconnecting from the grid.
They auto disconnect at 59.4hz.
Voltage is the easy part.
Con Edison in New York can reduce by a maximum of 8%I just saw that CNBC is reporting that PJM may have to cut power to some customers to protect the grid. What's your current voltage (and general area) today? Here at my house in the greater Seattle area, it's varying from 119.1V to 119.6V. I don't ever remember seeing it move around that much and we're not even in the middle of the heatwave..
https://www.cnbc.com/2026/07/03/power-grid-independence-day-weekend.html
Oh, no! Is the beer still cold?Currently 0 at my house. Storm came thru and dropped a tree on the power lines. ;-)
I got it now.No my workplace.
They still do that. Its all automatic now.Maybe 50 y ears ago the brought a Power Plant on line by synchronizing the frequency. Those days I believe are long gone (in the U.S)
The motel property I maintain has a 208/120 service its just about always dead on 212v when checking stoves, and hvac equipmentNo my workplace.
115 down to 110. AC runs most of the time. 100 today but the humidity is only in the forties which makes it bearable.I just saw that CNBC is reporting that PJM may have to cut power to some customers to protect the grid. What's your current voltage (and general area) today? Here at my house in the greater Seattle area, it's varying from 119.1V to 119.6V. I don't ever remember seeing it move around that much and we're not even in the middle of the heatwave..
A long time ago when our kids were little, a splice at our power pole let go and we had a big voltage sag. The lights went very dim and all the magic smoke escaped from our old CRT TV set (which was off). Pe-ew! Luckily our PC's and other electronics survived long enough for me to kill the power at the mains.back in the day 110 motors would operate on voltages down to around 90v not ideal torque would be low amp draw higher most electrical appliances were designed around 107, 115 and 117v before a modern more efficient grid of 110/120-220/240v. Motors were made beefy years ago heavy casings heavy copper windings added stress and heat from under voltage wouldn’t take them out so easily.
By electrical standards equipment has to be designed to operate 10% of its absolute lowest voltage rating. So a unit designed to operate 208-230/240v for 208 that’s 187v. Sensitive electronics such as logic boards and inverters are much more finicky and pose a higher risk of being taken out by low voltages.
Most accurate measurement would be at the panels main breaker checking off a wall receptacle depending on house load and where that receptacle is in the circuit could be significant voltage drop.I see that some of you have "monitors" of some type connected but are the rest of you just probing an outlet with a multi-meter ?
I used a Kill-a-Watt meter to measure mine. It looks like some folks are showing output from a UPS (Un-interuptible Power Supply).I see that some of you have "monitors" of some type connected but are the rest of you just probing an outlet with a multi-meter ?
Did you lose the neutral that happens and 120v appliances see 240 and you’ll get the smoke show with no magic.A long time ago when our kids were little, a splice at our power pole let go and we had a big voltage sag. The lights went very dim and all the magic smoke escaped from our old CRT TV set (which was off). Pe-ew! Luckily our PC's and other electronics survived long enough for me to kill the power at the mains.
Its a unit of my own design that publishes to HomeAssistant. I have a whole panel energy monitor that I made, CT (Current Transformers), as well as PT (Potential-Voltage Transformers). Overkill for residential but its fun for me. This way I can actually measure the true power and not just the Voltage*Current (Magnitude) that most consumer energy monitors (at least for whole panel) are setup for. It takes into account Distortion as well as Displacement Power Factor to arrive at the true power. While the unit obviously has no 3rd party lab credentials it was enough for me to dispute the power companies meter that had drifted with age and get them to change meters and issue me a refund a few years back.I see that some of you have "monitors" of some type connected but are the rest of you just probing an outlet with a multi-meter ?
I'm really not sure about that. I figured it was a voltage drop because the incandescent live bulbs got very dim.Did you lose the neutral that happens and 120v appliances see 240 and you’ll get the smoke show with no magic.
Unbalanced load from a lost neutral. leg a could have dropped to 90v leg b shot up to 150v if the lights that dimmed were on leg a that would have been why.I'm really not sure about that. I figured it was a voltage drop because the incandescent live bulbs got very dim.
