Unless you know the OEM filter efficiency there's little chance of certainty.just stating that he likely went backwards on filtration efficiency instead of forward as he thought.
key word: “likely”Unless you know the OEM filter efficiency there's little chance of certainty.
The Boss isn't much if any more efficient than the Toyota filters are.I just went to the Purolator BOSS for my 12 Kia Optima. Will change to the BOSS on my 23 RAV4 at the next oil change. I have confidence in their filters. Very well made. Decided that the Toyota filter isn't sufficient enough filtration for me.
Some of BR's "efficiency" ranking is out of correlation with the ISO 4548 test results ranking of the filters tested. I'll trust an official ISO 4548 test spec ranking between filters before any home-made gadage test results. Some of BR's results do seem to correlate to some degree, but there are out-flyers too. Their dP vs flow info is more believable for comparison and ranking.The BOSS does better in filtering than what people are stating. Watch the BR video. it's enough for me to see.
Price is the #1 factor for me but I am always within the premium filter lines. I buy Fram Ultra or Mobil 1 filters for the Tacoma, whichever is cheaper at the time. The Impala I have little choice, it is the old style original canister / cartridge filter that was phased out ~54 years ago, so far I have only used Wix but would be open to the Fram version, whichever is cheaper at the time of purchase. These old canister filters are never on sale.Does price play a part in your decision?
If you look at each filter media under a microscope you'll see that the BOSS has much better filtering material than the Toyota. And you can go to BR and see the particle count for each.the toyota has likely better filtration efficiency. the boss line is mostly 99% @ >46um. check out the post today about the new wire backed supertec filter.
Purolator states 20 micron filtering for 10k milesSome of BR's "efficiency" ranking is out of correlation with the ISO 4548 test results ranking of the filters tested. I'll trust an official ISO 4548 test spec ranking between filters before any home-made gadage test results. Some of BR's results do seem to correlate to some degree, but there are out-flyers too. Their dP vs flow info is more believable for comparison and ranking.
