What is Wix's nominal micron rating?
Zimbabwe
I put the 57055 on my car because I became educated about the bypass rating which I had ignored before. With this car you can either go with excellent filtering and bypass rating that's HALF what's spec'd, or specified bypass and mediocre (as far as I know) filtering.
The 57055 only gives efficiency ratings as "Nominal: 15 microns". No percents or anything. Anyone have any idea what this means?
It is not really worth worrying about. We put too much thought into oil filters . The most important thing about an oil filter is that is doesn't fail and kill the motor.
Looks like WIX is getting rid of the beta ratio (efficiency) info now on some of their filters.
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1870865
"Nominal" efficiency can mean a number of things, but typically one of them is the efficiency at 50%. Many of the WIX filters use to have a beta ratio of 95% @ 20 microns, but if they don't show that now, who knows what it really is.
Their website sure doesn't give you much help...you're missing half the equation. I would agree that "nominal" ratings are typically lower efficiency at x micron as the test involves the degree a certain size contaminant particle is filtered as a percentage of weight...whereas an "absolute" rating usually means no contaminant larger than the rated size can pass through the filter at 98%-99% or whatever efficiency and that will usually be listed.
It is very similar to Bose and definitive tech speakers....
They don't list wattage or frequency response @ rated THD. Rather they say.... "how do they sound to YOU?"
Would you buy a car that didn't list HP/torque numbers? Or the number of gears in the trans? Whether it had a timing belt or chain?
Of course not.
I'm not a fan of wavy wix trash
Of course not.
It was either that or the Subaru OEM filter which probably had filtering efficiency of 1% at 1cm.
ZeeOSix - Is WIX taking lessons from Mann-Hummel-Purolator by hiding efficiency numbers?
Could be ... see the upper right hand corner of their home page ... "Mann+Hummel".
Originally Posted By: Trav
Wix is a good filter, I wouldn't worry about it a bit. Worry more about keeping the air filter changed.
+1 simply because it is a wix.
Is this a relatively new filter, or a really old one? The 51358 (kind of in between) still lists both the nominal efficiency and the whitewashed beta ratios.
