Nominal Micron Rating ?
SACRAMENTO, CA
When a filter manuf. says the filter has a 12 nominal micron rating, what test do they use to ad. that rating? And can you take the claim (12 Nominal Micron Rating) and put it into a (b2=20) type of rating? Or are there two totally different test to get those numbers and they mean two different things?
ROD
"The term “nominal” micron rating typically means that the filter is capable of removing 50% of a specific size particle, however, some companies’ “nominal” micron ratings may range anywhere from 1 to 98.6% efficient at removing a specific particle size. The term “absolute” micron rating means that the filter is capable of removing at least 98.7% of a specific size particle. This rating is far more accurate." --- http://www.baldwinfilter.com/ProductHighlights122010.html
You may find a better explanation linked below. As noted nominal typically means a micron rating at 50%. That said reading the thread, there seems to be a fudge factor or wiggle room in that definition. In other words it's open to interpretation. And one site in the link says it's unreliable now.
Absolute is a better, and anything with an ISO 4548-12 testing note next to it. That is the standard test procedure for filter efficiency.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3229906/Nominal_vs_Absolute_micron_rat
Thank's for the info. I should have known that, I know I read about it before but I just could not remember where.
As one who uses and trust Baldwin(have for 45 years) I should have remember that that is where I read it.
I think I'll start playing some memory games now. LOL
Thank's Again,
ROD
